Jittery Transitions with MIDI Controller
Thanks: 53 times Was thanked: 9 time(s) in 3 post(s)
I’ve just started to use a Launchpad Mini Mk2 as a controller, and find that any transition apart from a straight “cut” is quite jittery, i.e. not smooth.
Also, trying to export the list of activators fails – it only exports a list of default MIDI devices, none of the events themselves. Wonder if anyone can shed any light, please?
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ AgentPete
It has to do with the "value" of the button press. The Launchpad essentially has two values for each button UP (0) and DOWN (127) If you set the button "value" to 127 (Down position), you will eliminate this "double click" effect of the default 0 (Up position).
Brilliant! Problem solved - thanks, Ice!
