[fixed] - ReplayMarkInOutLive duration wrong
Joined: 6/5/2019(UTC) Posts: 29  Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
Hello
i'm currently in a live event, and can't fix a crazy effect.
if a click on the replay -5 or -10, the durration of the new event is 24seconds longer example:
-5 results in -29 -10 results in -34 seconds same on midi-shortcut events
how i can fix this?
thx
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
check the events preroll settings of instant replay
it as 0 for pre and post, but i have reinput the 0 and now it works fine! .. THX so much!
xun
Glad its fixed but sounds like a little bug when you mention it was 0 already and reentering fixed it
Might be good idea to make Martin aware of this directly
