Can I use Fill and Key via two SDI inputs with vMix?
Joined: 8/15/2013(UTC) Posts: 108   Location: Could be Australia could be Europe/UK! Thanks: 2 times Was thanked: 9 time(s) in 9 post(s)
Hi Guys,
I need to bring into vMix some motion graphics from a DeckLink 4K card... it is supplied via two HD SDI outputs... one for fill and one for key...
Is it possible to use this setup to bring in Key info into vMix? If so how do I set it up?
thanks
Mike P
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
Mike, sorry but that's not possible . If you can set a solid color surrounding the graphics that is not being used in main graphic area then you could do a chromakey. Just remeber not have any shadow on outside edges other wise the key will not be clean.
Thanks for your reply... that is a shame... Ill add it to the feature requests page...
