aircooled76@gmail.com
#1 Posted : Monday, October 21, 2013 9:00:12 AM(UTC)
Hi Guys,
I need to bring into vMix some motion graphics from a DeckLink 4K card... it is supplied via two HD SDI outputs... one for fill and one for key...
Is it possible to use this setup to bring in Key info into vMix? If so how do I set it up?
thanks
Mike P
Egriswold
#2 Posted : Monday, October 21, 2013 2:53:17 PM(UTC)
Egriswold
Was thanked: 35 time(s) in 34 post(s)
Mike, sorry but that's not possible . If you can set a solid color surrounding the graphics that is not being used in main graphic area then you could do a chromakey. Just remeber not have any shadow on outside edges other wise the key will not be clean.
#3 Posted : Monday, October 21, 2013 8:44:12 PM(UTC)
Thanks for your reply... that is a shame... Ill add it to the feature requests page...
