Systems
Compact Rackmount for NDI - 1660Ti and i7-8700K..?
Joined: 10/17/2017(UTC) Posts: 9   Location: Near Paris Thanks: 5 times
Hi there,
We are building 2 new stations to operate All NDI environment, no need to go 4K
Regular use will be : > 3 NDI Inputs from Bird Dog P200 ptz > 2 NDI|Hx Inputs from Spark Connect devices > 2 NDI Outputs > 1 recording channel > 1 Streaming up to 1080p60
Equipment will be travelling a lot, by train or car, with "care". We need to rack it in the Gator GRR-8L roling flycase
Thus we would like to use a 3U Rackmount case, any advice more thena welcome!
Mobo - ASUS TUF Z390M-Pro Gaming : Micro ATX Socket 1151 Intel Z390 Express - 4x DDR4 - SATA 6Gb/s + M.2 - USB 3.1 - 2x PCI-Express 3.0 16x - Wi-Fi AC GPU - ASUS GeForce GTX 1660 Ti DUAL-GTX1660TI-O6G CPU - Intel Core i7-8700K (3.7 GHz) Memory - Ballistix Sport AT 32 Go (4 x 8 Go) DDR4 2666 MHz CL16 Power - Seasonic FOCUS Plus 550 Gold Storage - Kingston KC2000 M.2 PCIe NVMe 2 To Cooler Master GeminII M4 + Noctua NF-A6x25
+ Optional = would this system handle an additional 1 input capture card?
How does it sound to you guys? This will be our 2 first custom builds, unfortunately budget is a concern...
Many thanks for your help/comments Not read that much in the forums on the i7-8700K, nor on the GTX1660Ti..?
Ben
Here in the 3U case that we would go for: [img=https://imgur.com/RsOFrvO]3U Case[/img] PLINKUSA-RACKBUY-Micro-ATX-Rackmount-IPC-3013S On Amazon  temp.png (210kb) downloaded 7 time(s).
You need to watch the height of the GPU. Often you need a 4RU case for them to fit.
 2 users thanked ask for this useful post.
Thanks for your input
True, this is one of our concern
The case is 133.35 mm height, and the 1660Ti is advertised as 121.00 mm
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
4U all the way. I made that mistake. Also have to remember power connectors on most GPU are on top of cards which adds more height. Originally Posted by: RiverBen  Thanks for your input
 2 users thanked desmar for this useful post.
If you must go the 3U route, take a look at these low profile 90-degree GPU power cables from Kareon Kables. Bailed me out a time or two. custom cables- Tom
 2 users thanked sinc747 for this useful post.
Thanks Tom & desmar for sharing experiences
Didn't have this connectors possible issue in mind!
Take a look at this 2U Case from Plink, with riser card and cage for GPU. Might be an option also. I was looking at this one for a client, before going to a 4U case.. Plink IPC-G252SOriginally Posted by: RiverBen  Thanks Tom & desmar for sharing experiences
 1 user thanked desmar for this useful post.
Thanks for the link
I think we will go for the 4U, final call later this week
Maybe you guys have some thoughts about the GPU match : 1660 Ti vs 2060 ?
Systems
