RiverBen
#1 Posted : Thursday, May 30, 2019 6:25:28 PM(UTC)
RiverBen
Hi there,
We are building 2 new stations to operate All NDI environment, no need to go 4K
Regular use will be :
> 3 NDI Inputs from Bird Dog P200 ptz
> 2 NDI|Hx Inputs from Spark Connect devices
> 2 NDI Outputs
> 1 recording channel
> 1 Streaming up to 1080p60
Equipment will be travelling a lot, by train or car, with "care".
We need to rack it in the Gator GRR-8L roling flycase
Thus we would like to use a 3U Rackmount case, any advice more thena welcome!
Mobo - ASUS TUF Z390M-Pro Gaming : Micro ATX Socket 1151 Intel Z390 Express - 4x DDR4 - SATA 6Gb/s + M.2 - USB 3.1 - 2x PCI-Express 3.0 16x - Wi-Fi AC
GPU - ASUS GeForce GTX 1660 Ti DUAL-GTX1660TI-O6G
CPU - Intel Core i7-8700K (3.7 GHz)
Memory - Ballistix Sport AT 32 Go (4 x 8 Go) DDR4 2666 MHz CL16
Power - Seasonic FOCUS Plus 550 Gold
Storage - Kingston KC2000 M.2 PCIe NVMe 2 To
Cooler Master GeminII M4 + Noctua NF-A6x25
+ Optional = would this system handle an additional 1 input capture card?
How does it sound to you guys?
This will be our 2 first custom builds, unfortunately budget is a concern...
Many thanks for your help/comments
Not read that much in the forums on the i7-8700K, nor on the GTX1660Ti..?
Ben
RiverBen
#2 Posted : Thursday, May 30, 2019 6:54:03 PM(UTC)
RiverBen
Here in the 3U case that we would go for:
[img=https://imgur.com/RsOFrvO]3U Case[/img]
PLINKUSA-RACKBUY-Micro-ATX-Rackmount-IPC-3013S
On Amazon
ask
#3 Posted : Thursday, May 30, 2019 10:50:16 PM(UTC)
ask
You need to watch the height of the GPU. Often you need a 4RU case for them to fit.
thanks 2 users thanked ask for this useful post.
sinc747 on 5/31/2019(UTC), RiverBen on 6/3/2019(UTC)
RiverBen
#4 Posted : Thursday, May 30, 2019 11:33:14 PM(UTC)
RiverBen
Thanks for your input
True, this is one of our concern
The case is 133.35 mm height, and the 1660Ti is advertised as 121.00 mm
desmar
#5 Posted : Friday, May 31, 2019 5:42:15 AM(UTC)
desmar
Canada
4U all the way. I made that mistake.
Also have to remember power connectors on most GPU
are on top of cards which adds more height.
thanks 2 users thanked desmar for this useful post.
sinc747 on 5/31/2019(UTC), RiverBen on 5/31/2019(UTC)
sinc747
#6 Posted : Friday, May 31, 2019 7:39:43 AM(UTC)
sinc747
If you must go the 3U route, take a look at these low profile 90-degree GPU power cables from Kareon Kables. Bailed me out a time or two.
custom cables
- Tom
thanks 2 users thanked sinc747 for this useful post.
RiverBen on 5/31/2019(UTC), lael on 9/2/2019(UTC)
RiverBen
#7 Posted : Friday, May 31, 2019 6:18:03 PM(UTC)
RiverBen
Thanks Tom & desmar for sharing experiences
Didn't have this connectors possible issue in mind!
desmar
#8 Posted : Saturday, June 1, 2019 5:22:39 AM(UTC)
desmar
Canada
Take a look at this 2U Case from Plink, with riser card and cage for GPU.
Might be an option also. I was looking at this one for a client, before going to a 4U case..
Plink IPC-G252S
thanks 1 user thanked desmar for this useful post.
RiverBen
#9 Posted : Monday, June 3, 2019 10:26:03 PM(UTC)
RiverBen
Thanks for the link
I think we will go for the 4U, final call later this week
RiverBen
#10 Posted : Monday, June 3, 2019 10:27:43 PM(UTC)
RiverBen
Maybe you guys have some thoughts about the GPU match : 1660 Ti vs 2060 ?
