bgbenni
#1 Posted : Saturday, June 1, 2019 9:02:20 AM(UTC)
bgbenni
Germany
i send over a CSV date informations to vmix, the scoreboard time.
the time from the CSV is 23:12:999 but i will show in Vmix only 3:12 i have test it with {m:ss} on Format but it´s not working.
Any idea how can i fix this in Vmix without changing the data input from the CSV
#2 Posted : Saturday, June 1, 2019 5:31:20 PM(UTC)
Was thanked: 1013 time(s) in 832 post(s)
{0} should do just fine
bgbenni
#3 Posted : Saturday, June 1, 2019 6:19:39 PM(UTC)
bgbenni
Germany
with {0} it shows me the 23:12:999 from the CSV but i need only 3:12 if i add {mm:ss} its nothing change
#4 Posted : Saturday, June 1, 2019 7:10:42 PM(UTC)
my apologies but i understood it wouldn't write the whole time rather than you just wanting the front part only
you time in the csv file is not a value but a string . can't do conversions in a title field
from the helpfile : Format: This option can be used to add additional text to the data, for example "Name: {0}" will output the data as "Name: Bob"
bgbenni on 6/1/2019(UTC)
