Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
i send over a CSV date informations to vmix, the scoreboard time. the time from the CSV is 23:12:999 but i will show in Vmix only 3:12 i have test it with {m:ss} on Format but it´s not working. Any idea how can i fix this in Vmix without changing the data input from the CSV
with {0} it shows me the 23:12:999 from the CSV but i need only 3:12 if i add {mm:ss} its nothing change
my apologies but i understood it wouldn't write the whole time rather than you just wanting the front part only
you time in the csv file is not a value but a string . can't do conversions in a title field
from the helpfile : Format: This option can be used to add additional text to the data, for example "Name: {0}" will output the data as "Name: Bob"
