JohnnyFlash
#1 Posted : Friday, May 31, 2019 10:43:48 AM(UTC)
JohnnyFlash
I have a lower 3rd title that cycles between two sets of information.
While they worked perfectly in 22.0.0.57, the second set of info never becomes visible in 22.0.0.60
I know that some sort of hidden feature was added in .60 but the titles work in GT Designer so I would expect them to work in vMix.
I have included my .gtzip file so you can investigate the problem.
The animations are on Page1-4, with Page3 showing the bad behavior.
Thanks!
lower3rd.gtzip (211kb) downloaded 33 time(s).
#2 Posted : Friday, May 31, 2019 9:37:31 PM(UTC)
From the GT Title Designer, under the Storyboard toolbar section, click the green notebook icon.
You will see all the animations you have setup. I note there are many duplicates where the first animation for an object is set to fade but the second is set to hidden
which will conflict with each other, so you may need to go through all the animations and remove any that shouldn't be there to get the desired results.
JohnnyFlash
#3 Posted : Tuesday, June 4, 2019 6:59:28 AM(UTC)
JohnnyFlash
So are you saying the two versions don't work the same way?
I reverted back to .57 and everything started working again.
Also they work as expected in GT Designer.
Did hidden change somehow in .60 as part of the API changes to allow the turning on and off of assets?
I'm just confused as how I am able to create settings in the editor that work, but don't work in the latest version of vMix.
#4 Posted : Tuesday, June 4, 2019 12:32:53 PM(UTC)
It is possible we fixed a bug, but the new changes we added won't affect existing titles.
Again, since you have duplicate transitions that conflict with each other, this is likely what is causing the problem
and it may be random if it works or not depending on version for this reason.
JohnnyFlash
#5 Posted : Thursday, June 6, 2019 8:04:23 AM(UTC)
JohnnyFlash
I have verified all the transitions. There was only one that was conflicting, but the hidden transition has been removed.
Titles are still not working correctly in 22.0.0.60
Titles still work perfectly in GT Designer and 22.0.0.57
#6 Posted : Thursday, June 6, 2019 12:31:27 PM(UTC)
Can you post a short video of how it is supposed to look.
The title had at least 4 conflicting hidden/fade transitions when I checked.
Note Hidden can't be combined with other transitions on the same object overlapping the same times.
JohnnyFlash
#7 Posted : Friday, June 7, 2019 9:09:22 AM(UTC)
JohnnyFlash
Here's the sample.
Here's the script I use to animate them automatically. The Sub-Scripts have function calls for each Lower3rd. I have included a single call as an example.
While TRUE
API.Function("ScriptStart",,"Lower3rdsON") 'Function=TitleBeginAnimation&Value=Page1&Input=8b972153-d272-46e3-9b4f-28fe02829bf6
Sleep(12000)
API.Function("ScriptStart",,"Lower3rds-Data0") 'Function=TitleBeginAnimation&Value=Page3&Input=8b972153-d272-46e3-9b4f-28fe02829bf6
Sleep(12000)
For i As Integer = 1 to 4
API.Function("ScriptStart",,"Lower3rds-Data1") 'Function=TitleBeginAnimation&Value=Page4&Input=8b972153-d272-46e3-9b4f-28fe02829bf6
Sleep(12000)
Sleep(12000)
Next
API.Function("ScriptStart",,"Lower3rdsOFF") 'Function=TitleBeginAnimation&Value=Page2&Input=8b972153-d272-46e3-9b4f-28fe02829bf6
Sleep(30000)
End While
Let me know if there is anything else I can do.
#8 Posted : Friday, June 7, 2019 1:25:42 PM(UTC)
Thanks for that.
After trying a number of things, it looks like the issue occurred due to how the preset was last saved.
It was saved when the Page 2 transition was running, which has the text fields set to hidden.
When the preset is open again, those hidden states are restored, even though that particular transition is no longer running.
To fix this, the input will need to be removed, and added again as a brand new input and the preset saved when
it is either in the TransitionIn state, or not running at all and turned off in the overlay.
On our end we will work on a fix in the next update.
euomauricio
#9 Posted : Tuesday, August 18, 2020 5:11:15 AM(UTC)
euomauricio
Brazil
Originally Posted by: admin Go to Quoted Post
Thanks for that.
hello, i have the same problem.
And even in a new preset, my titles do not appear.
It is totally black.
#10 Posted : Tuesday, August 18, 2020 5:16:08 AM(UTC)
Have you updated to the latest v22 ?
also know that titles only active when in overlay
