kevev
#1 Posted : Wednesday, November 7, 2018 12:30:09 AM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
https://pcpartpicker.com/list/9c6zGG
Can someone let me know if this hardware is sufficient for replay only via NDI 4x inputs @ 1080p60? I have SSDs, RAM, and a Mouse, so no need to purchase those.
kevev
#2 Posted : Monday, November 19, 2018 1:04:37 PM(UTC)
kevev
For anyone wondering, yes this hardware can handle the requirements. We have used it for 2 football games and had no problems.
thanks 3 users thanked kevev for this useful post.
dasmedienatelier on 12/3/2018(UTC), kjones9999 on 12/26/2018(UTC), Torg on 4/21/2019(UTC)
hi808
#3 Posted : Saturday, December 22, 2018 11:21:02 AM(UTC)
hi808
Thinking about building dedicated replay computer too, do you have to pay for another license? You all output ndi from replay computer, ndi in show computer? Stable?
Barney Box Lane
#4 Posted : Monday, December 24, 2018 1:25:36 AM(UTC)
Barney Box Lane
we've got one just for ease of separating things and when you have to tinker with a trim adjustment it's a much simpler set up even if you're operating both comps you basically just have a bigger UI.
You don't have to get another if you're using it like that in a reasonable way. I wouldn't use it to run a seperate show etc it just helps with workflow being able to spread it.
Torg
#5 Posted : Thursday, April 18, 2019 5:23:28 PM(UTC)
Torg
What SSD are you using?
bgbenni
#6 Posted : Thursday, April 18, 2019 7:45:03 PM(UTC)
bgbenni
Germany
My experience with the GTX 1050 are no so good on my new laptops i use the GTX1060 but the Laptop versions.
with the 1050 i had to much GPU overload.
for the case if you won't have a smaller one (THETIS Midi-Tower). Its a little bit tricky to get everything in but its from the size better.
kevev
#7 Posted : Friday, April 19, 2019 2:58:47 AM(UTC)
kevev
Samsung 860
Siroki
#8 Posted : Wednesday, May 29, 2019 12:18:04 AM(UTC)
Siroki
Bosnia and Herzegovina
Was thanked: 27 time(s) in 24 post(s)
I was making production for TV, boxing tournament.
Had graphics on external render and one camera replay (1080i) setup (around 10-15 inputs). BMD decklink duo 2 and mini recorder.
i7 4770, 12GB RAM, 256 SSD samsung EVO 860 and graphic card radeon rx 580 4GB
the procesor was around 12%, sometimes in short time jumps to 17%, and goes back around 12%
So if someone is thinking to buy or make this kind of setup I was very satisfied with this. It was a first time I used replay like this
