Instant Replay
Building separate vMix replay system
Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
https://pcpartpicker.com/list/9c6zGGCan someone let me know if this hardware is sufficient for replay only via NDI 4x inputs @ 1080p60? I have SSDs, RAM, and a Mouse, so no need to purchase those.
For anyone wondering, yes this hardware can handle the requirements. We have used it for 2 football games and had no problems.
 3 users thanked kevev for this useful post.
Thinking about building dedicated replay computer too, do you have to pay for another license? You all output ndi from replay computer, ndi in show computer? Stable?
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
we've got one just for ease of separating things and when you have to tinker with a trim adjustment it's a much simpler set up even if you're operating both comps you basically just have a bigger UI. You don't have to get another if you're using it like that in a reasonable way. I wouldn't use it to run a seperate show etc it just helps with workflow being able to spread it.
You have been a member since:: 12/31/2017(UTC) Posts: 11 Location: Italy
Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: kevev  https://pcpartpicker.com/list/9c6zGG
Can someone let me know if this hardware is sufficient for replay only via NDI 4x inputs @ 1080p60? I have SSDs, RAM, and a Mouse, so no need to purchase those. What SSD are you using?
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
My experience with the GTX 1050 are no so good on my new laptops i use the GTX1060 but the Laptop versions. with the 1050 i had to much GPU overload.
for the case if you won't have a smaller one (THETIS Midi-Tower). Its a little bit tricky to get everything in but its from the size better.
Originally Posted by: Torg  Originally Posted by: kevev  https://pcpartpicker.com/list/9c6zGG
Can someone let me know if this hardware is sufficient for replay only via NDI 4x inputs @ 1080p60? I have SSDs, RAM, and a Mouse, so no need to purchase those. What SSD are you using? Samsung 860
Joined: 10/10/2015(UTC) Posts: 322   Location: Siroki Brijeg Thanks: 8 times Was thanked: 27 time(s) in 24 post(s)
I was making production for TV, boxing tournament. Had graphics on external render and one camera replay (1080i) setup (around 10-15 inputs). BMD decklink duo 2 and mini recorder.
i7 4770, 12GB RAM, 256 SSD samsung EVO 860 and graphic card radeon rx 580 4GB
the procesor was around 12%, sometimes in short time jumps to 17%, and goes back around 12%
So if someone is thinking to buy or make this kind of setup I was very satisfied with this. It was a first time I used replay like this
Instant Replay
