NDI
Using a Newtek Spark with Ubiquiti Access Point
Joined: 7/24/2018(UTC) Posts: 96 Location: Carrollton, GA
Thanks: 1 times Was thanked: 15 time(s) in 11 post(s)
Hello, I am interested if anyone is currently using a regular camera plugged in to a spark, then sending that signal back to the switcher over something like a nano station? Curious what the latency is like, how does it look being sent NDI-HX, and how far out are you going with it?
I recently using my PTZ optics camera and send NDI-HX out of the camera to a nano station then over to the switcher. Very little delay and able to control the PTZ camera.
Rank:: Advanced Member
Thanks for a link to that video. Do you think the latency would be less if it were through a spark and not RTSP from the camera?
300ms is slightly better than what I got doing this through a HDMI to Lan converter.
The Spark is NDI|HX so latency will be the same as the PTZOptics camera.
But the PTZ optics camera does not have to convert HDMI to NDI-HX. It comes directly out of the camera. I am hoping and maybe assuming that there wont be much added delay going camera-HMI-Spark-Nano Station but curious if anyone has some real examples they have done before I buy a spark. Also I am considering the Kiloview instead of the spark since it already contains a batter and a mount
Following up to my own post. I was going to get a spark but came across a deal on a Birddog mini. I have tested this with a Ubiquiti access point and have very minimal delay. After talking to the nice folks at Birddog they recommended I limit my transmitting to 720 @ 60 FPS due to bandwidth. I am fine with that, and so far testing has gone well. NDI HX would be a smaller bandwidth but a slightly longer delay according to the Birddog reps.
Originally Posted by: Radiotvpat1982  But the PTZ optics camera does not have to convert HDMI to NDI-HX. It comes directly out of the camera. I am hoping and maybe assuming that there wont be much added delay going camera-HMI-Spark-Nano Station but curious if anyone has some real examples they have done before I buy a spark. Also I am considering the Kiloview instead of the spark since it already contains a batter and a mount The signal path is fundamentally similar. The video stream from the sensor is RGB. It gets encoded, whether internally or externally. I would expect NDI|HX to be marginally faster than normal RTMP.
NDI
