Novation Launchpad Mini MKII and activators
Is it a way through VMIX to make LED buttons blink? Like a blinking red button as recording is in progress?
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
If your midi device supports it, it's possible
Just create an activator, under "Type" choose the kind of button you're using and underneath it you can choose the colour and/or blinking (eg red blinking).
It's documented in the manual...
The device supports it indeed (I can do this manually through Ableton Live). Anyone here who is using blinking LEDs on a Novation Launchpad through Vmix?
Joined: 2/23/2019(UTC) Posts: 139  Thanks: 20 times Was thanked: 29 time(s) in 26 post(s)
I don't have a launchpad (yet) but there are programming guides for the Launchpad Mk2 and for the Launchpad. I can't link to them without my message being rejected as spam!
For the launchpad, which seems most similar to the Mini Mk2, you have to send a special value to get it to flash. It doesn't look like these are set up under the type "Novation LED Button" in vMix so I think it will have to be a feature request to get it added.
For the Launchpad Mk2, if you set a colour on channel 2 it will flash between that and black. If you set a colour on channel 1 followed by one on channel 2 it flash between the two. Sending a colour on channel 1 on its own will show that colour and stop any flashing.
Joined: 12/6/2018(UTC) Posts: 6  Location: Melbourne Thanks: 3 times
This was something I played around with a little while ago. My solution was to use Bomes Midi Translator. https://www.bome.com/products/miditranslatorI used it to intercept a midi message from VMix and forward on the midi message that would make the lights flash or pulse. It was a fair amount of work and ended up being a little difficult to make any changes two as you would need to remember which colour in vmix would translate to a particular colour flashing or pulsing.
I made a script yesterday, as a workaround, that puts a transparent input as overlay every 0.5 seconds. And turns this overlay on and off. And I made a activator that is looking for the active overlay. It works, but it is a scripting loop, and there are some disadvantages running a script turning overlays on/off. Maybe I should try to get a Launchpad MKII ... :)
