No Audio when video goes to overlay (old problem - but not solved)
Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
I wrote about this a long time ago - when sending video to overlay (by buttons in input or shortcut) - the sound from video does not go to the master. If i create trigger - "OnOverlayIn" to "Audio" and ithis input as audio source - audio go to the master when overlay enabled. BUT - if i once click left button of mouse over this video (as example - to see it on preview window) - sound disabled !
Dear friends. Сan you make that sound settings in the input properties work for the overlay mode (AutoMix audio) ?
@ snapoid
To the best of my knowledge, it has always been this way and that this is by design.
I know it. But it causes some inconvenience :(
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
If you have trigger set, did you try to uncheck automix ?
I use trigger OnOverlayIn to enable audio from this input - it is work. BUT - if i click left button of mouse under input tab (when i need to see this input in preview window - timing or etc) - audio off...
try to uncheck automatically mix audio in input general panel.
