Feature Requests
USB Device Reset or Refresh
Thanks: 21 times Was thanked: 11 time(s) in 9 post(s)
Devices such as Shuttle have to be plugged in before running vMix. This is fine. But during a Live Event, it is possible that the device, being reliant on Windows and rock solid plugs and connectors, may glitch or a cable may be bumped during an event. If this happens, the shuttle no longer works, and the only way to reset it is to close vMix and reopen it. This of course means stopping the Live Event.
It would be good if the USB device could be reset or refreshed in some way, without having to restart vMix.
Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
Joined: 7/6/2013(UTC) Posts: 45   Location: Slangor Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: grantcoll  Devices such as Shuttle have to be plugged in before running vMix. This is fine. But during a Live Event, it is possible that the device, being reliant on Windows and rock solid plugs and connectors, may glitch or a cable may be bumped during an event. If this happens, the shuttle no longer works, and the only way to reset it is to close vMix and reopen it. This of course means stopping the Live Event.
I also experienced what happened to you. And now I find the simplest way, close source usb device on vMix, enter the device manager, then desible usb device that is problematic and we enable it again. then we add it again on vMix. Regards
 1 user thanked sontoloyo for this useful post.
sontoloyo, my example of this problem is with Shuttle. How do you close the Shuttle in vmix ? it is not a source usb device.
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
Joined: 5/29/2018(UTC) Posts: 76  Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
+1
Same problem 2-3 times
Feature Requests
