grantcoll
#1 Posted : Wednesday, April 3, 2019 11:47:54 AM(UTC)
grantcoll
Devices such as Shuttle have to be plugged in before running vMix. This is fine. But during a Live Event, it is possible that the device, being reliant on Windows and rock solid plugs and connectors, may glitch or a cable may be bumped during an event. If this happens, the shuttle no longer works, and the only way to reset it is to close vMix and reopen it. This of course means stopping the Live Event.
It would be good if the USB device could be reset or refreshed in some way, without having to restart vMix.
kevev
#2 Posted : Thursday, April 4, 2019 12:52:41 AM(UTC)
kevev
Was thanked: 8 time(s) in 4 post(s)
+1
sontoloyo
#3 Posted : Thursday, April 4, 2019 2:49:21 AM(UTC)
sontoloyo
Malaysia
I also experienced what happened to you. And now I find the simplest way, close source usb device on vMix, enter the device manager, then desible usb device that is problematic and we enable it again. then we add it again on vMix.
Regards
thanks 1 user thanked sontoloyo for this useful post.
hehsoy on 4/4/2019(UTC)
grantcoll
#4 Posted : Tuesday, May 14, 2019 9:36:21 AM(UTC)
grantcoll
sontoloyo, my example of this problem is with Shuttle. How do you close the Shuttle in vmix ? it is not a source usb device.
avsoundguy
#5 Posted : Monday, May 20, 2019 3:37:46 AM(UTC)
avsoundguy
Was thanked: 9 time(s) in 8 post(s)
+1
bgbenni
#6 Posted : Monday, May 20, 2019 4:34:13 AM(UTC)
bgbenni
+1
Same problem 2-3 times
