dominiik
#1 Posted : Wednesday, May 15, 2019 5:24:22 AM(UTC)
dominiik
Switzerland
hello,
is there a way to send out four inputs to four HD-SDI outputs on a Blackmagic Decklink card?
or only two and the rest to NDI only?
thank you for your feedback,
Dominik
zenvideo
#2 Posted: : Wednesday, May 15, 2019 8:04:59 AM(UTC)
zenvideo
Which Decklink card? There are quite a few different models...
dominiik
#3 Posted : Wednesday, May 15, 2019 11:31:24 PM(UTC)
dominiik
Switzerland
i have the Decklink duo with 4x HD-SDI...
zenvideo
#4 Posted : Thursday, May 16, 2019 12:03:03 AM(UTC)
zenvideo
So were you wanting to use all four SDI channels as outputs from vMix? Although a Duo 2 card can use all four channels as outputs, the limitation in vMix is for 2 external outputs in the 4K & Pro editions, and just one in Basic & HD. You potentially can have two "full screen" outputs (via the graphics card), which could externally be converted from HDMI to SDI, if that's of any help.
dominiik
#5 Posted : Thursday, May 16, 2019 12:10:21 AM(UTC)
dominiik
Switzerland
hi
thank you for your feedback. my customer said me it should be possible with four outputs on vMix.
i just want to have confirmed i am not wrong with my knowledge vMix can only do two outputs on SDI.
thank you.
Dominik
stigaard
#6 Posted : Thursday, May 16, 2019 1:25:22 AM(UTC)
stigaard
Denmark
vMix can only output 2 signals to a physical device (SDI/HDMI/analog). vMix has two additional outputs (output 3 and 4) which can be used to for NDI purposes or etc.
dominiik
#7 Posted : Thursday, May 16, 2019 1:30:02 AM(UTC)
dominiik
Switzerland
thank you all for your feedback.
my soulution will now be to give two outputs to a other pc with vMix and a 2nd Decklink Duo.
with this i have 4 outputs to SDI.
Dominik
doa
#8 Posted : Thursday, May 16, 2019 5:58:39 AM(UTC)
doa
Netherlands
vMix can output 4 physical outputs if you use external renderer.
For example:
I have a Helios 500 and use:
1xhdmi
1xDP
1xSDI (external rederer BlackMagic UltraStudio 4K)
