hello,
is there a way to send out four inputs to four HD-SDI outputs on a Blackmagic Decklink card? or only two and the rest to NDI only?
thank you for your feedback, Dominik
Joined: 5/13/2014(UTC) Posts: 424   Location: Manchester, UK Thanks: 2 times Was thanked: 160 time(s) in 110 post(s)
Which Decklink card? There are quite a few different models...
i have the Decklink duo with 4x HD-SDI...
Originally Posted by: dominiik  i have the Decklink duo with 4x HD-SDI... So were you wanting to use all four SDI channels as outputs from vMix? Although a Duo 2 card can use all four channels as outputs, the limitation in vMix is for 2 external outputs in the 4K & Pro editions, and just one in Basic & HD. You potentially can have two "full screen" outputs (via the graphics card), which could externally be converted from HDMI to SDI, if that's of any help.
hi
thank you for your feedback. my customer said me it should be possible with four outputs on vMix. i just want to have confirmed i am not wrong with my knowledge vMix can only do two outputs on SDI. thank you.
Dominik
Joined: 5/20/2015(UTC) Posts: 470   Location: Copenhagen, Denmark Thanks: 325 times Was thanked: 94 time(s) in 76 post(s)
vMix can only output 2 signals to a physical device (SDI/HDMI/analog). vMix has two additional outputs (output 3 and 4) which can be used to for NDI purposes or etc.
thank you all for your feedback. my soulution will now be to give two outputs to a other pc with vMix and a 2nd Decklink Duo. with this i have 4 outputs to SDI.
Dominik
Joined: 6/16/2013(UTC) Posts: 12   Location: Netherlands,Lelystad Thanks: 20 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: stigaard  vMix can only output 2 signals to a physical device (SDI/HDMI/analog). vMix has two additional outputs (output 3 and 4) which can be used to for NDI purposes or etc. vMix can output 4 physical outputs if you use external renderer. For example: I have a Helios 500 and use: 1xhdmi 1xDP 1xSDI (external rederer BlackMagic UltraStudio 4K)
