vMix not (yet) working with Ustream
I try to broadcast to Ustream, But it isn't working.
What I did : Settings / External Output Tabblad : External Output and choose :vMix Virtual Device Choice : Pal 50i or 25p 720x576
Then I go to "External" (in the bottom of the screen) When I pus Start I get an error screen : Invalid Handle Source : DeckLink
When I look in Ustream I see in the 'Video Source" vMix Virtual Capture but all I see is a black screen.
Can you help ? Rgds, Daan
Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4729 time(s) in 1621 post(s)
If you are using Vista/Windows 7, vMix will need to be run as an administrator. So right click vMix shortcut and choose "run as administrator".
That was a good ti. Thanks !! But It's still not working. I Adobe Flash Media Encoder I select the Device : vMix Virtual Capture
When I start AFME I get the error :
Problem with video capture device Please verify that the video capture device is working correctly and is not already in use.
This error is shown when I started VMix and even when Vmix is not started I get the above error.
Hope you can reproduce this error.
Rgds, Daan
I have just tested with Flash Media Encoder and can confirm there is a bug. I will try to get this fixed for the next release. Thanks.
