videologic
#1 Posted : Tuesday, April 20, 2010 3:23:45 PM(UTC)
videologic
I try to broadcast to Ustream, But it isn't working.
What I did :
Settings / External Output
Tabblad : External Output and choose :vMix Virtual Device
Choice :
Pal 50i or 25p
720x576
Then I go to "External" (in the bottom of the screen)
When I pus Start I get an error screen : Invalid Handle Source : DeckLink
When I look in Ustream I see in the 'Video Source" vMix Virtual Capture but all I see is a black screen.
Can you help ?
Rgds, Daan
#2 Posted : Wednesday, April 21, 2010 2:42:03 AM(UTC)
Was thanked: 4740 time(s) in 1626 post(s)
If you are using Vista/Windows 7, vMix will need to be run as an administrator.
So right click vMix shortcut and choose "run as administrator".
videologic
#3 Posted : Saturday, May 1, 2010 5:26:40 PM(UTC)
videologic
That was a good ti. Thanks !! But It's still not working.
I Adobe Flash Media Encoder I select the Device : vMix Virtual Capture
When I start AFME I get the error :
Problem with video capture device
Please verify that the video capture device is working correctly and is not already in use.
This error is shown when I started VMix and even when Vmix is not started I get the above error.
Hope you can reproduce this error.
Rgds, Daan
#4 Posted : Sunday, May 2, 2010 3:17:44 AM(UTC)
I have just tested with Flash Media Encoder and can confirm there is a bug.
I will try to get this fixed for the next release. Thanks.
