donvago
#1 Posted : Friday, May 10, 2019 7:18:41 AM(UTC)
donvago
It is possible to share a computer screen with vmixcall, just like skype or hongout does?
#2 Posted : Friday, May 10, 2019 9:03:21 AM(UTC)
@ donvago
If doing a vMix to vMix Call, either party can use the vMix DeskTop Capture Input to share on screen.
Otherwise, if using a browser to connect, only the Host can share their screen in vMix (as per above), since the browser has no option to share the screen.
donvago
#3 Posted : Friday, May 10, 2019 11:52:03 PM(UTC)
donvago
Originally Posted by: IceStream Go to Quoted Post
@ donvago
And assuming, that one of the parties connects to the browser and has the desktop capture.
the receiving party that has the vmix can capture its screen?
donvago
#4 Posted : Saturday, May 11, 2019 1:41:34 AM(UTC)
donvago
@ donvago
That is the question.
If one of the parties has vmix and the other is from the browser and the desktop capture ... The one that is connected from the vmix could capture the other's screen?
#5 Posted : Saturday, May 11, 2019 10:13:20 PM(UTC)
@ donvago
No...
The vMix Desktop Capture Application needs to be on the same network for vMix to see it (as per NDI protocols).
If you want to capture the caller's screen, they will need to have vMix installed (even the free vMix Basic will work) and then use the "Connect to call" option to do a vMix to vMix Call.
(it will require the caller to have a working knowledge of vMix operation).
mavik
#6 Posted : Tuesday, May 14, 2019 5:48:23 PM(UTC)
mavik
You can use the free NDI tools to capture the screen and send the NDI over WAN into your vMix production system. Take a look at medialooks transport software. That will do it.
mjgraves
#7 Posted : Tuesday, May 14, 2019 9:37:01 PM(UTC)
mjgraves
WebRTC, the tech underlying vMix Call, does support screen capture. Many webrtc apps, like https://meet.jit.si, can do it. vMix Call, at present, does not support this.
sinc747 on 5/18/2019(UTC)
tomthinks
#8 Posted : Thursday, May 23, 2019 7:04:58 AM(UTC)
tomthinks
It would really be amazing if vMix Call did support connecting to an NDI Scan Converter. I have a situation where I have guests who use Mac computers and I really wish they could share screen with my broadcast. For now I just have to use Google Hangouts instead..
mjgraves
#9 Posted : Saturday, May 25, 2019 2:45:32 AM(UTC)
mjgraves
On Windows your vMix Caller could use a virtual webcam app like Logitech Capture. It can select the webcam, desktop, or even overlay the two. For example:
Logitech Capture app: Ovelaying 4K Desktop and Brio webcam
tomthinks on 6/11/2019(UTC)
mjgraves
#10 Posted : Thursday, June 20, 2019 12:56:34 AM(UTC)
mjgraves
Another alternative is to use OBS. In OBS you can compose a scenes that gets conveyed to the browser (vMix Call) as a webcam.
I accept that OBS is beyond a lot of people.
P.S. - I'm told that the virtual webcam support for OBS is via a plugin that's windows only.
