play next video (input) automatically
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
is there a way to play a video or any input in the preview window automatic as next, as soon the active video has finished?
Hallo,
Trigger - OnCompletion - Cut (etc.) - Preview.
thanks, but this has to be set on every input. it would be cool to set this trigger on the output.
Hallo,
Einmal erstellen, dann bei jedem Video, welches automatisch eine Vorschau in den Ausgang laden muss, auf Trigger gehen und unten links auf " Kopie von .." klicken und den erstellten Trigger suchen.
Create once, then with each video, which automatically has to load a preview into the output, go to Trigger and click on "Copy from .." in the lower left corner and search for the created trigger.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
you can't set triggers on the output because it's not accurate this sounds like the playlist does most of what you're looking for though
thanks for all good advices. my producer does not work like this. he has a few videos or images ready and decides during a playing video, which next. in livestream studio this is a standard feature, if a video is in preview window, it will be played automatically next. just with one option to choose, autoplay preview yes/no with this option i can put any source in preview, if a video runs, preview will be disolved next automatically. i will go for the trigger option on the inputs. thanks
set up two lists with the same content loaded and throw it between lists?
