Peter1000
#1 Posted : Monday, May 6, 2019 11:35:06 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
is there a way to play a video or any input in the preview window automatic as next, as soon the active video has finished?
elvis55
#2 Posted : Monday, May 6, 2019 11:54:39 PM(UTC)
elvis55
Switzerland
Hallo,
Trigger - OnCompletion - Cut (etc.) - Preview.
Peter1000
#3 Posted : Tuesday, May 7, 2019 2:03:33 AM(UTC)
Peter1000
Switzerland
thanks, but this has to be set on every input.
it would be cool to set this trigger on the output.
elvis55
#4 Posted : Tuesday, May 7, 2019 3:13:27 AM(UTC)
elvis55
Switzerland
Hallo,
Einmal erstellen, dann bei jedem Video, welches automatisch eine Vorschau in den Ausgang laden muss,
auf Trigger gehen und unten links auf " Kopie von .." klicken und den erstellten Trigger suchen.
Create once, then with each video, which automatically has to load a preview into the output,
go to Trigger and click on "Copy from .." in the lower left corner and search for the created trigger.
Barney Box Lane
#5 Posted : Tuesday, May 7, 2019 7:30:10 PM(UTC)
Barney Box Lane
you can't set triggers on the output because it's not accurate this sounds like the playlist does most of what you're looking for though
Peter1000
#6 Posted : Tuesday, May 7, 2019 7:41:37 PM(UTC)
Peter1000
Switzerland
thanks for all good advices. my producer does not work like this. he has a few videos or images ready and decides during a playing video, which next.
in livestream studio this is a standard feature, if a video is in preview window, it will be played automatically next. just with one option to choose, autoplay preview yes/no
with this option i can put any source in preview, if a video runs, preview will be disolved next automatically.
i will go for the trigger option on the inputs.
thanks
Barney Box Lane
#7 Posted : Wednesday, May 8, 2019 6:05:19 PM(UTC)
Barney Box Lane
set up two lists with the same content loaded and throw it between lists?
