Henrik
#1 Posted : Thursday, April 18, 2019 1:55:00 AM(UTC)
Henrik
Germany
I need a shortcut to change the MarkIn and MarkOut position by defined values like "MarkIn -=x" and "MarkOut +=x".
For a live Event we only use 10 Sek. replay event. To do a highlight cut, those 10 sek are sometimes to short. To change each single event needs to long, so a shortcut to extend like "MarkIn -=10" and "MarkOut +=5" to get a 25 sek. clip would be great! Maybe change all selected events.
Henrik
#2 Posted : Thursday, April 18, 2019 4:40:15 AM(UTC)
interesting
well we have ReplayJumpFrames (+ or -) and also ReplayUpdateSelectedInPoint & ReplayUpdateSelectedOutPoint
I think as a combined shortcut could do something
selecting an event puts you at the beginning so that works directly , the endpoint is a bit more tricky but as they are say ten seconds (25*10 or 30*10 approx) plus the extra wanted to jump there could work (not tested and don't know hom many frames one can specify)
krassesPferd
#3 Posted : Thursday, April 18, 2019 8:56:17 AM(UTC)
krassesPferd
Was thanked: 8 time(s) in 7 post(s)
There already exist shortcuts called "ReplayMoveSelectedInPoint" and "ReplayMoveSelectedOutPoint" with a value provided in frames (f.ex. -250 means 10 seconds earlier when producing with interlaced framerates)
Maybe this helps you
Best regards
Yannick
