Feature Requests
Change MarkIn/MarkOut Shortcut
Joined: 3/12/2019(UTC) Posts: 22  Location: Hamburg Was thanked: 3 time(s) in 3 post(s)
I need a shortcut to change the MarkIn and MarkOut position by defined values like "MarkIn -=x" and "MarkOut +=x".
For a live Event we only use 10 Sek. replay event. To do a highlight cut, those 10 sek are sometimes to short. To change each single event needs to long, so a shortcut to extend like "MarkIn -=10" and "MarkOut +=5" to get a 25 sek. clip would be great! Maybe change all selected events.
Thanks Henrik
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
interesting
well we have ReplayJumpFrames (+ or -) and also ReplayUpdateSelectedInPoint & ReplayUpdateSelectedOutPoint I think as a combined shortcut could do something selecting an event puts you at the beginning so that works directly , the endpoint is a bit more tricky but as they are say ten seconds (25*10 or 30*10 approx) plus the extra wanted to jump there could work (not tested and don't know hom many frames one can specify)
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
There already exist shortcuts called "ReplayMoveSelectedInPoint" and "ReplayMoveSelectedOutPoint" with a value provided in frames (f.ex. -250 means 10 seconds earlier when producing with interlaced framerates) Maybe this helps you
Best regards Yannick
Feature Requests
