Automatically Play Output Input with Transition
Joined: 4/17/2019(UTC) Posts: 4  Was thanked: 2 time(s) in 1 post(s)
Is there a way to put a video in program without automatically play it? I just want to prepare the next video showing it first frame and then play it only when I'm ready. I tried to deselect "Automatically Play Active Input with Transition" option (which in my vmix is strangely renamed in "Automatically Play Output Input with Transition") with no luck: it simply does not change anything in the behaviour as far as I can see.
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
Open input settings, under general ypu will find option to turn off "Automatically Play with Transition"
do I have to do this for every input? is there a way to do it once for all?
the options mentioned in settings become a basis all new inputs if you have them all already loaded then yes you will have to change them all
have you tried it ?
