santa
#1 Posted : Wednesday, April 17, 2019 6:52:04 PM(UTC)
santa
Italy
Is there a way to put a video in program without automatically play it?
I just want to prepare the next video showing it first frame and then play it only when I'm ready.
I tried to deselect "Automatically Play Active Input with Transition" option (which in my vmix is strangely renamed in "Automatically Play Output Input with Transition") with no luck: it simply does not change anything in the behaviour as far as I can see.
MartLeib
#2 Posted : Thursday, April 18, 2019 1:51:32 AM(UTC)
MartLeib
Estonia
Open input settings, under general ypu will find option to turn off "Automatically Play with Transition"
santa
#3 Posted : Thursday, April 18, 2019 2:43:23 AM(UTC)
santa
Italy
do I have to do this for every input?
is there a way to do it once for all?
#4 Posted : Thursday, April 18, 2019 4:46:13 AM(UTC)
the options mentioned in settings become a basis all new inputs
if you have them all already loaded then yes
you will have to change them all
have you tried it ?
