Hi All
Just wanted to check if vMix is compatible with Nvidia SDI solution E.g. K6000 + Nvidia SDI input and SDI out put
Regards
taz
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
I wouldn't use anything less than a P series Quadro card. See link below for supported video encode/decode supported. https://developer.nvidia.com/video-encode-decode-gpu-support-matrix Quadro.png (67kb) downloaded 2 time(s).Originally Posted by: tazdas  Hi All
Just wanted to check if vMix is compatible with Nvidia SDI solution E.g. K6000 + Nvidoutputinput and SDI out put
Regards
taz
Thanks, but in memory (GPU) computation using Quadro SDI solution had advantages as well, ofcourse it wont be as fast as native encode/decode support in the GPU.
