tazdas
#1 Posted : Saturday, April 13, 2019 6:16:44 AM(UTC)
tazdas
Canada
Hi All
Just wanted to check if vMix is compatible with Nvidia SDI solution E.g. K6000 + Nvidia SDI input and SDI out put
Regards
taz
desmar
#2 Posted : Saturday, April 13, 2019 1:22:12 PM(UTC)
desmar
Canada
I wouldn't use anything less than a P series Quadro card.
See link below for supported video encode/decode supported.
https://developer.nvidia.com/video-encode-decode-gpu-support-matrix
Originally Posted by: tazdas Go to Quoted Post
Hi All
Just wanted to check if vMix is compatible with Nvidia SDI solution E.g. K6000 + Nvidoutputinput and SDI out put
Regards
taz
tazdas
#3 Posted : Sunday, May 5, 2019 11:01:23 AM(UTC)
tazdas
Canada
Thanks, but in memory (GPU) computation using Quadro SDI solution had advantages as well, ofcourse it wont be as fast as native encode/decode support in the GPU.
