jvphobic
#1 Posted : Friday, April 12, 2019 10:13:29 AM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
This is my first time trying to use the Multicorder. And It appears that when I enable it on 2 NDI streams I get a TON of .mp4 files with an xml file. Is this what is supposed to happen? Or am I missing something obvious.
#2 Posted : Friday, April 12, 2019 3:11:05 PM(UTC)
If the NDI source is not a consistent stream, i.e desktop capture then it will likely create a lot of small recordings
as MultiCorder needs to create a new file if there is a gap longer than 1 second.
Instead, route the desktop capture input to an output channel and record that in MultiCorder instead.
