Multicorder General Question
Joined: 6/23/2016(UTC) Posts: 106 Location: Milwaukee
Thanks: 1 times Was thanked: 11 time(s) in 10 post(s)
This is my first time trying to use the Multicorder. And It appears that when I enable it on 2 NDI streams I get a TON of .mp4 files with an xml file. Is this what is supposed to happen? Or am I missing something obvious.
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
If the NDI source is not a consistent stream, i.e desktop capture then it will likely create a lot of small recordings as MultiCorder needs to create a new file if there is a gap longer than 1 second.
Instead, route the desktop capture input to an output channel and record that in MultiCorder instead.
