Systems
(4K BUILD) Intel Core i9-7940X VS AMD Ryzen Threadripper 2950X
Joined: 3/7/2019(UTC) Posts: 9  Location: Medellin Thanks: 1 times
Hello!
Im looking for a ULTRA HARD WORK desktop for a University, so we think in future, we have now 3 cameras at 4K output, but in the future we will buy more. We works at setups with "8 cameras" (3-4K & 6-FHD) We record and stream concerts, soccer plays, conferences.
So the specs for the computer that we are thinking to buy are this:
Win 10 Pro vMix Pro 2X LG 27UD68P-B. (4K) 1X Cooler Master HAF XB EVO 1X Intel Core i9-7940X X-Series 3.1 GHz 14-Core 1X Cooler Master MasterLiquid Pro 240 1X Gigabyte X299 Designare EX 1X PNY NVIDIA Quadro P5000 1X Frontal SD Reader STARTECH USB 3.0 1X EVGA Supernova 1300 G2 120-G2-1300-XR 1300W 80 Plus Gold ATX12V & EPS12V Power Supply 2X Blackmagic Design DeckLink 8K Pro (8 channels with 4K capability each one) 1X DeckLink Quad HDMI Recorder (4 channels at 4K for laptops and aux sources) 1X SHINESTAR Firewire Card, PCIe Firewire Adapter for Windows 1X Samsung 970 EVO 2TB 1X Samsung 860 EVO 2TB 1X Seagate BarraCuda 8TB 1X CORSAIR Vengeance LPX 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 2666
So i recently see that the Intel Core i9-7940X only can handle 44 PCIe Lanes, that means that i cannot put all of the capture cards that i would like, check it: GRAPHIC CARD x16 DeckLink 8K Pro X8 DeckLink 8K Pro X8 Quad HDMI Recorder X8 SSD M2 X4 FIREWIRE CARD X1 TOTAL: X45 Without thinking about others components on the motherboard that can need more PCIe lanes.
Also recently i see another CPU: AMD Ryzen Threadripper 2950X. Cheaper and more pcie lanes (x60), but i dont know if it can works perfectly with vMIX, because i see anothers posts that says that its a wrong choice.. I think an AMD build for 4x4K60 cameras + 8xFHD sources:
Win 10 Pro vMix Pro CPU: AMD 2nd Gen Ryzen 2950X Motherboard: GIGABYTE X399 AORUS XTREME sTR4 1X AMD Wraith Ripper by Cooler Master 1X PNY NVIDIA Quadro P5000 1X Cooler Master HAF XB EVO 2X LG 27UD68P-B. (4K) 1X Frontal SD Reader STARTECH USB 3.0 1X EVGA Supernova 1300 G2 120-G2-1300-XR 1300W 80 Plus Gold ATX12V & EPS12V Power Supply 2X Blackmagic Design DeckLink 8K Pro (8 channels with 4K capability each one) 1X DeckLink Quad HDMI Recorder (4 channels at 4K for laptops and aux sources) 1X SHINESTAR Firewire Card, PCIe Firewire Adapter for Windows 1X Samsung 970 EVO 2TB 1X Samsung 860 EVO 2TB 1X Seagate BarraCuda 8TB 1X CORSAIR Vengeance LPX 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 2666
What do you think about this new AMD build?
Joined: 5/14/2018(UTC) Posts: 114 Location: Netherlands
Thanks: 3 times Was thanked: 33 time(s) in 19 post(s)
Hi there Manuel,
The threadripper does work with vmix, however Ryzen is not the recommended hardware for Vmix, and I would only advice so if it were a multi-role machine also doing other tasks that work well on Ryzen (like some specific rendering programs).
A quick look tells me that you would probably be better off with a Intel system regardless due the high count of 4k Inputs.
NOw the good bit I can tell you is that you have 24 PciE lanes from the X299 chipset (as per intel specs) adding to the 44 of the CPU. However, the motherboard itself only has 3 slots above 4x meaning one of the 4k cards couldnt be used on full pull. One way to work around this is by using an external PLX PciE hub, allowing you to house 2 x8 cards (or more lower cards) on one slot. However, these cost enough to consider moving some or all I/O into separate systems that only do conversion (about 2ms more latency compared to built-in I/O)
 1 user thanked Vuurmannetje for this useful post.
NOw the good bit I can tell you is that you have 24 PciE lanes from the X299 chipset (as per intel specs) adding to the 44 of the CPU. However, the motherboard itself only has 3 slots above 4x meaning one of the 4k cards couldnt be used on full pull. One way to work around this is by using an external PLX PciE hub, allowing you to house 2 x8 cards (or more lower cards) on one slot. However, these cost enough to consider moving some or all I/O into separate systems that only do conversion (about 2ms more latency compared to built-in I/O) When you said "moving some or all I/O into separate systems" what would you recommend to me to add to the build? Thanks for reply
NOw the good bit I can tell you is that you have 24 PciE lanes from the X299 chipset (as per intel specs) adding to the 44 of the CPU. However, the motherboard itself only has 3 slots above 4x meaning one of the 4k cards couldnt be used on full pull. One way to work around this is by using an external PLX PciE hub, allowing you to house 2 x8 cards (or more lower cards) on one slot. However, these cost enough to consider moving some or all I/O into separate systems that only do conversion (about 2ms more latency compared to built-in I/O) You said that i have 44-CPU plus 24-Motherboard? Finally i got 68 PCIe lanes? Also in this case, there are another motherboard that can handle this build without external devices?
Yes, thats correct. But the motherboard dictates how many of them are actually available on PCIE.
I havent researched the available boards enough to give you a name. I use an Aorus x299 for my biggest server (with an i9 9800x) which has 6 slots I believe, not sure on exact distribution of lanes but I believe theyre all x8 or higher. But make sure to check specs!
Originally Posted by: manuelgomezo  Originally Posted by: Vuurmannetje  Hi there Manuel,
NOw the good bit I can tell you is that you have 24 PciE lanes from the X299 chipset (as per intel specs) adding to the 44 of the CPU. However, the motherboard itself only has 3 slots above 4x meaning one of the 4k cards couldnt be used on full pull. One way to work around this is by using an external PLX PciE hub, allowing you to house 2 x8 cards (or more lower cards) on one slot. However, these cost enough to consider moving some or all I/O into separate systems that only do conversion (about 2ms more latency compared to built-in I/O) When you said "moving some or all I/O into separate systems" what would you recommend to me to add to the build? Thanks for reply The wonders of NDI are that you can add I/O with almost no latency to a Vmix or NDI based system just by adding NDI sources. There are hardware converters like the magewell 4k that do all in one to NDI, but more cost effective if you already have SDI installed is by using lower spec converter systems, youd still have to research specifics, but one can for example use a 8400f with a single 8k card as the only load and send 4 4k streams into NDI (though you might need a 10gb NIC/network for that depending on exact settings).
Joined: 4/15/2018(UTC) Posts: 64  Location: Spain Thanks: 6 times Was thanked: 19 time(s) in 13 post(s)
Vmix ndi inputs add 1.5-2 frames latency. How do you get zero?. I get always lower latency with capture cards on vmix. Other software do not add latency to ndi like vmix. But of course are not vmix.
Originally Posted by: Vuurmannetje  Originally Posted by: manuelgomezo  Originally Posted by: Vuurmannetje  Hi there Manuel,
NOw the good bit I can tell you is that you have 24 PciE lanes from the X299 chipset (as per intel specs) adding to the 44 of the CPU. However, the motherboard itself only has 3 slots above 4x meaning one of the 4k cards couldnt be used on full pull. One way to work around this is by using an external PLX PciE hub, allowing you to house 2 x8 cards (or more lower cards) on one slot. However, these cost enough to consider moving some or all I/O into separate systems that only do conversion (about 2ms more latency compared to built-in I/O) When you said "moving some or all I/O into separate systems" what would you recommend to me to add to the build? Thanks for reply The wonders of NDI are that you can add I/O with almost no latency to a Vmix or NDI based system just by adding NDI sources. There are hardware converters like the magewell 4k that do all in one to NDI, but more cost effective if you already have SDI installed is by using lower spec converter systems, youd still have to research specifics, but one can for example use a 8400f with a single 8k card as the only load and send 4 4k streams into NDI (though you might need a 10gb NIC/network for that depending on exact settings). We dont like NDI for camera sources, we can think it for laptops and another sources. So, we look that specs finally to build the pc, what do you think about it? Win 10 Pro vMix Pro First Display: LG 27UD68P-B. (4K) Case: Cooler Master HAF XB EVO Intel Core i9-7940X X-Series 3.1 GHz 14-Core Motherboard: Gigabyte X299-WU8 Cooler Master MasterLiquid Pro 240 PNY NVIDIA Quadro P5000 SD Frontal Reader STARTECH USB 3.0 EVGA Supernova 1300 G2 120-G2-1300-XR 1300W 80 Plus Gold ATX12V & EPS12V Power Supply Blackmagic Design DeckLink 8K Pro DeckLink Quad HDMI Recorder SHINESTAR Firewire Card, PCIe Firewire Adapter for Windows Samsung 970 EVO 2TB Samsung 860 EVO 2TB Seagate BarraCuda 8TB CORSAIR Vengeance LPX 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 2666 Backlit keyboard+mouse
I have a p5000 and i think is better p6000 or rtx5000 if you will use a lot of 4k. I like quadro because no limit on nvenc, and custom edid. But if you do not need this, better to go 1080ti or rtx2080ti I personally do not like any hdd on the system, i prefer to use externally for backups and all inside pc ssd or nvme. For nvme try to add some heatsink to help on hot environment. 1300w psu i think is too much, with 800-1000 is enough. I use 700w psu and never need more than 500w. Big psu is for gaming with multi graphics cards. And vmix actually just use only one card.
Jose.
Originally Posted by: JoseL  I have a p5000 and i think is better p6000 or rtx5000 if you will use a lot of 4k. I like quadro because no limit on nvenc, and custom edid. But if you do not need this, better to go 1080ti or rtx2080ti I personally do not like any hdd on the system, i prefer to use externally for backups and all inside pc ssd or nvme. For nvme try to add some heatsink to help on hot environment. 1300w psu i think is too much, with 800-1000 is enough. I use 700w psu and never need more than 500w. Big psu is for gaming with multi graphics cards. And vmix actually just use only one card.
Jose. P6000 or RTX5000 are really expensive, like 2500 dollars more. We can’t afford it. So, the multiple Nvenc can help us with replays or multicorder for 3 cameras plus program and stream
Systems
