2 Pages<12
tech7a
#21 Posted : Wednesday, March 20, 2019 10:53:04 PM(UTC)
tech7a
Bahrain
Originally Posted by: zenvideo Go to Quoted Post
...look at the vMix Help, under Input Settings -> General...
There you will find a full description of the options for each input (with a picture). That's what I was describing to you.
thanks for help i will try and will tell you...
tech7a
#22 Posted : Thursday, March 21, 2019 3:26:47 PM(UTC)
tech7a
Bahrain
Hi brother
i check the camera output is 1080P59 from setting camera
how make correct settings in vmix for take output 1080P30
thank you again
tech7a
#23 Posted : Friday, March 22, 2019 4:33:54 AM(UTC)
tech7a
Bahrain
Is it possible to post a frame grab that shows the problem? Sounds like it might be related to interlaced video.
thank very much now working perfect in two capture..
i change the frame and working
thank you
2 Pages<12
