Originally Posted by: zenvideo  ...look at the vMix Help, under Input Settings -> General... There you will find a full description of the options for each input (with a picture). That's what I was describing to you.
thanks for help i will try and will tell you...
Hi brother i check the camera output is 1080P59 from setting camera how make correct settings in vmix for take output 1080P30 thank you again
Originally Posted by: zenvideo  Is it possible to post a frame grab that shows the problem? Sounds like it might be related to interlaced video. thank very much now working perfect in two capture.. i change the frame and working thank you
