Rinsky
#1 Posted : Monday, March 18, 2019 6:54:25 PM(UTC)
Rinsky
It would be very handy to have an export function to not only export the graphics as a single .png file, but also the whole animation as an image sequence to use the same graphics for post in other applications.
#2 Posted : Monday, March 18, 2019 8:16:23 PM(UTC)
I see where you are getting at ;-)
what if you recorded the title action (on green color input) and use the vMix videotool to create the image sequence ?
stevespaw
#3 Posted : Wednesday, March 20, 2019 12:07:50 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Record the output as NDI with alpha using NewTek codec with alpha, and use adobe media encoder, for example, and export the NewTek video as sequential PNG.
A work around but a manageable workflow.
Steve
