Joined: 10/10/2013(UTC) Posts: 9   Location: Groeslon wales Thanks: 2 times
Vmix is not seeing flash encoder on my computer .error message appears say no coder found check it's the atest etc, when the coder is running and can see vmix's external output, it is the latest version down loaded directly from Adobe? Best regards Peter. '
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
Please make sure FMLE is installed to the default installation directory. This will be C:\Program Files (x86)\Adobe\Flash Media Live Encoder 3.2
Martin vMix
Done, but sill not working?
Are you using 32bit or 64bit windows? If 32bit, install to C:\Program Files\Adobe\Flash Media Live Encoder 3.2
What is the full error message when trying to stream once installed?
Martin vMix
Thank you Martin I finally , got it going last night all working properly. Many thanks for your help best regards Peter gw7bzy. Wales UK
