Peter
#1 Posted : Thursday, October 10, 2013 10:40:06 AM(UTC)
Peter
Vmix is not seeing flash encoder on my computer .error message appears say no coder found check it's the atest etc, when the coder is running and can see vmix's external output, it is the latest version down loaded directly from Adobe? Best regards Peter.
#2 Posted : Thursday, October 10, 2013 1:13:43 PM(UTC)
Please make sure FMLE is installed to the default installation directory.
This will be C:\Program Files (x86)\Adobe\Flash Media Live Encoder 3.2
Peter
#3 Posted : Friday, October 11, 2013 2:54:03 PM(UTC)
Peter
Done, but sill not working?
#4 Posted : Friday, October 11, 2013 9:51:31 PM(UTC)
Are you using 32bit or 64bit windows?
If 32bit, install to C:\Program Files\Adobe\Flash Media Live Encoder 3.2
What is the full error message when trying to stream once installed?
Peter on 10/17/2013(UTC)
Peter
#5 Posted : Thursday, October 17, 2013 7:47:49 AM(UTC)
Peter
Thank you Martin I finally , got it going last night all working properly. Many thanks for your help best regards Peter gw7bzy. Wales UK
