2 Pages12>
Quinton
#1 Posted : Friday, March 8, 2019 3:13:58 AM(UTC)
Quinton
Was thanked: 7 time(s) in 4 post(s)
Just trying to up a scoreboard by +1 using streamdeck only, without using vmix shortcuts.
How would the api function work (or can it not)?
I can do it with vmix shortcuts easily enough, but can't seem to get it working in a browser.
With the API you only have SetText,Value,Input, but if you want to do it using a url you need "Title Too" like..
localhost:8088/api/?Function=SetText&Input=1&Title=AwayScore&Value=+1
Any ideas how this can be done with a direct Function?
#2 Posted : Friday, March 8, 2019 3:27:51 AM(UTC)
What is wrong with letting the streamdeck use a vmix shortcut or api call ?
How else would a streamdeck be able to do it ?
Quinton
#3 Posted : Friday, March 8, 2019 3:35:13 AM(UTC)
Quinton
I am able to do most things without using vmix shortcuts, just directly using a localhost api function.
Is it not possible to add or take away 1 to a score through a browser link?
If so, what would that link be as you also need to use a "title" to get it to work so it gets to the right place.
#4 Posted : Friday, March 8, 2019 3:35:18 AM(UTC)
or as of vMix 22
Knowledge base
Quinton
#5 Posted : Friday, March 8, 2019 3:42:13 AM(UTC)
Quinton
I know how to use the streamdeck and vmix, that is not a problem.
I want to know if its possible to use the API to count up a score +1 using localhost function alone.
SetText does not seem to have a "title" option, only value,input
#6 Posted : Friday, March 8, 2019 4:15:40 AM(UTC)
for title use SelectedIndex or SelectedName depending if you use the index or the name of
but +=1 doesnt work for value addition
#7 Posted : Friday, March 8, 2019 4:27:39 AM(UTC)
Actually this works
http://localhost:8088/api/?Function=SetText&Input=1&SelectedIndex=1&Value=%2b%3d1
for +=1
Quinton
#8 Posted : Friday, March 8, 2019 6:14:46 AM(UTC)
Quinton
Actually this works
for +=1
That works perfectly, many thanks once again.
Out of interest how was the %2b%3d1 for (+=1) worked out as I need -=1 too :)
#9 Posted : Friday, March 8, 2019 6:23:31 AM(UTC)
ASCII URL Encoding
see toward bottom of page https://www.w3schools.com/tags/ref_urlencode.asp
Quinton on 3/8/2019(UTC)
MartLeib
#10 Posted : Friday, March 8, 2019 6:25:39 AM(UTC)
MartLeib
Estonia
Actually this works
for +=1
-%3D1
Quinton
#11 Posted : Friday, March 8, 2019 6:45:29 AM(UTC)
Quinton
Thanks..I'm picking this up slowly but surely :)
I find it much easier doing it this way, as trying to find the shortcut I just made within vmix can be quite hard I think the way it is.
Quinton
#12 Posted : Saturday, June 29, 2019 2:27:56 AM(UTC)
Quinton
Sorry for posting this in a couple of places, but I need to try and get this working before tomorrow..
Has the Input format for vmix and companion app changed, since the last time I used it?
Trying to set up a goal up/down pause time.set time etc, and seems its now not the same as last time. I just entered "PauseCountdown Input=1" which worked to pause the clock, but now I am trying to add +1 to a particular score, before it would have been like this, but seems that is not working anymore?
Anyone Help out why its not working anymore? SetText&Input=1&SelectedIndex=3&Value=%2b%3d1
raugert
#13 Posted : Saturday, June 29, 2019 2:58:34 AM(UTC)
raugert
Canada
Was thanked: 322 time(s) in 184 post(s)
Try using SelectedName instead of SelectedIndex. (Note: If you really want to use SelectedIndex.. remember it starts at 0 ). You might be sending it to the wrong field in your xaml title.
#14 Posted : Saturday, June 29, 2019 3:28:29 AM(UTC)
is there an initial value in the textfield ?
Quinton
#15 Posted : Saturday, June 29, 2019 4:25:34 AM(UTC)
Quinton
Sending to right field, as it works perfectly when entering it in a browser, just doesnt work with companion.
There is already a number (score) entered to begin with.
Would be grateful if anyone has an answer to this, as I want to use the companion emulator remotely on a phone to change scores, which would be much easier that changing a datasource.
Just doesnt seem to want to work, even though it did a few months ago.
Quinton
#16 Posted : Saturday, June 29, 2019 4:45:00 AM(UTC)
Quinton
Seems like a lot of things arent working in companion now.
For example ..
http://localhost:8088/api/?Function=ChangeCountdown&Input=1&Value=00:45:00&SelectedIndex=0
This would set the time to 45 mins in a soccer match for the start of half time, no way I can see that works in companion...works fine in a browser.
In companion pause/restart countdown is simply PauseCountdown Input=1 which does work, so I am def connected properly.
This should add 1 to the score, again using a browser not a problem but doesnt work anymore in companion.
#17 Posted : Saturday, June 29, 2019 5:03:39 AM(UTC)
Is there a companion group, forum or page as it really looks like a companion problem and not a vMix one ?
Quinton
#18 Posted : Saturday, June 29, 2019 5:10:34 AM(UTC)
Quinton
There is indeed, I already posted there but no luck.
Just posted here to see if I was doing something stupid, that was resolved easily last time, would love just to use a single brwoser page for the shortcuts with the buttons clearly showing. Seems like I will have to try and do it a different way.
kjones9999
#19 Posted : Friday, July 5, 2019 1:58:45 PM(UTC)
kjones9999
Are you using the general Post Http in companion? If not that is what is needed to make an API call through companion.
Quinton
#20 Posted : Friday, July 5, 2019 5:48:27 PM(UTC)
Quinton
Can you point me in the right direction where the Post HTTP is in companion, I was trying to use the run custom command in the dropdown, I dont see anything anywhere for http?
Guest (13)
2 Pages12>
