Very bad quality live streaming
Hello, I tried to do a multiple stream on Youtube and Facebook LIVE and it was completely bad. Video and audio stopping and fragmented all the time. I then decided to do just one stream on Youtube, it was better but still fragmented. So then I decided to stream just the audio so black picture appearing and the audio was ok. Can you help me to understand what is wrong? When I do Skype videocall I never have issues, so I doubt that is a connection problem. What do you suggest?
My laptop is a Toshiba and the features are:
Windows 10 Home Processore Intel® Core™ i7-4710HQ di 4a generazione con Intel® Turbo Boost Technology 2.0 39.6cm (15.6”) , Toshiba TruBrite® Full HD TFT High Brightness IPS display with LED backlighting, 16 : 9 aspect ratio Hard disk 1 TB Smart silver con finiture in alluminio spazzolato, tastiera nera 12,288 (8,192 + 4,096) MB, DDR3L RAM (1,600 MHz) AMD Radeon™ R9 M265X Enthusiast Graphics
THank you!!
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
Radeon is not recommended as a graphics card, and if Skype and vmix are working it'll probably be your stream settings so have a look at trying different bitrates.
Thank you, yes Skype works and vMix too on my side, but when I stream it's all fragmented and stopping What bitrate do you suggest? And what graphic card too? (maybe you can suggest a laptop)
we use Asus rog 7502 vw
for vmix you would want Nvidia gtx 1060 - you won't see a significant performance increase with 1070 or 1080
start with the lowest - 990kbps
also go to speedtest on Google, your stream should be half of your upload speed ie 2mbs UPLOAD speed you would do a 1mb or 990kbps stream
 1 user thanked Barney Box Lane for this useful post.
Thank you! I checked now and I have 1 mbs in upload so I have to look for 500kbps, do you think it's enough for a streaming that have not to be excellent but just fluent at least?
I am trying to check how to setup the bitrate but cannot find it, could please suggest it?
You have been a member since:: 2/17/2019(UTC) Posts: 4
Originally Posted by: dioni  I am trying to check how to setup the bitrate but cannot find it, could please suggest it? If your win 10 is buid 1809 downgrade a build 1803
