JohnnyBG
#1 Posted : Thursday, February 14, 2019 5:48:55 AM(UTC)
JohnnyBG
Is there an app or maybe some other way to use an Android cell phone as a camera that can output the video via NDI and have vMix recognize it as an NDI input?
elvis55
#2 Posted : Thursday, February 14, 2019 6:00:52 AM(UTC)
elvis55
Switzerland
Was thanked: 57 time(s) in 51 post(s)
JohnnyBG
#3 Posted : Thursday, February 14, 2019 7:49:29 AM(UTC)
JohnnyBG
This sounds like exactly what I am looking for. However, I read several reviews from users of the product and most are not very complimentary.
mjgraves
#4 Posted : Thursday, February 28, 2019 3:20:51 AM(UTC)
mjgraves
It works reasonably well. However, it implies NDI over Wi-Fi, which can be problematic. It needs really robust, fast Wi-Fi.
The likely use of Wi-Fi is exactly why Newtek created NDI|HX, the reduced-bandwidth, compressed and delayed variant.
Sadly, NDI|HX encoders are only in hardware at present. No way to encode NDI|HX on a smart phone. You're better off using an RTMP camera app.
mavik
#5 Posted : Thursday, February 28, 2019 9:10:38 AM(UTC)
mavik
Was thanked: 187 time(s) in 167 post(s)
NDI App works ok for me. If you switch to RTMP like mjgraves said some apps act as a rtmp server, some need an rtmp server. In the former case connect vMix to the stream. In the latter case you would need a mini Server something like http://garaninapps.com/pro
