Joined: 9/26/2014(UTC) Posts: 108  Location: Canada Thanks: 39 times Was thanked: 5 time(s) in 5 post(s)
I am wondering if I can use the output HTTP stream preset in MXLight as an input to vMIX?
From MXLight help:
This preset is designed for quickly setting up streaming across a local network. The hardware AV stream is used directly so no re-encoding is performed.
Once streaming is active the stream will be available via http at the selected destination. This takes the following form:
http://{IP}:{Port}/{Stream name}.ts
This can be played by players such as VLC.
I am thinking the vMIX input would be "Web Browser"
I do not have my ATEM TVS here at home but will bring it home later today and test it
Has anyone tried this approach?
Whit
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 75 time(s) in 57 post(s)
 1 user thanked stevespaw for this useful post.
Originally Posted by: stevespaw  Thanks I played around with various combinations and permutations of the MXLight streaming options and the vMIX inpit options. That was a lengthy task (for me at least). I got the result I wanted by choosing: In MXLIght stream using MPEG-TS Raw Output to local hostIn vMix input selection choosing TS TCP Pull tcp://127.0.0.1:41116The real issue now, the event is tomorrow and we have a game tonight!........
