calamityjane
#1 Posted : Saturday, February 23, 2019 1:12:16 AM(UTC)
calamityjane
I am wondering if I can use the output HTTP stream preset in MXLight as an input to vMIX?
From MXLight help:
This preset is designed for quickly setting up streaming across a local network. The hardware AV stream is used directly so no re-encoding is performed.
Once streaming is active the stream will be available via http at the selected destination. This takes the following form:
http://{IP}:{Port}/{Stream name}.ts
This can be played by players such as VLC.
I am thinking the vMIX input would be "Web Browser"
I do not have my ATEM TVS here at home but will bring it home later today and test it
Has anyone tried this approach?
Whit
stevespaw
#2 Posted : Saturday, February 23, 2019 2:22:02 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
https://www.vmix.com/help22/Stream.html
This is a bug in the help, it does not mention the VLC input type here. The VLC type will work perfectly.
Steve
thanks 1 user thanked stevespaw for this useful post.
calamityjane on 2/23/2019(UTC)
calamityjane
#3 Posted : Saturday, February 23, 2019 7:55:33 AM(UTC)
calamityjane
Steve
I played around with various combinations and permutations of the MXLight streaming options and the vMIX inpit options. That was a lengthy task (for me at least).
I got the result I wanted by choosing:
In MXLIght stream using MPEG-TS Raw Output to local host
In vMix input selection choosing TS TCP Pull tcp://127.0.0.1:41116
The real issue now, the event is tomorrow and we have a game tonight!........
