Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Sorry if this is a stupid question but... According to the documentation the Recording Setup page should support the ability to select the audio mix to record:  Pic1.png (24kb) downloaded 3 time(s).However this is what my Recording Setup page looks like:  Pic2.png (30kb) downloaded 1 time(s).So where is the Audio mix selection ? Thanks, Peter.
Originally Posted by: petervk  Sorry if this is a stupid question but... According to the documentation the Recording Setup page should support the ability to select the audio mix to record:  Pic1.png (24kb) downloaded 3 time(s).However this is what my Recording Setup page looks like:  Pic2.png (30kb) downloaded 1 time(s).So where is the Audio mix selection ? Thanks, Peter. This is totally a guess, but is it possible you don't have A and B busses enabled?
Joined: 1/13/2010(UTC) Posts: 5,352  Location: Gold Coast, Australia Was thanked: 4759 time(s) in 1633 post(s)
The option to select an audio bus will not appear if recording audio source in Settings -> Audio has been manually changed. Change this back to vMix Audio and it should appear as expected.
Originally Posted by: admin  The option to select an audio bus will not appear if recording audio source in Settings -> Audio has been manually changed. Change this back to vMix Audio and it should appear as expected.  2019-03-06_20-20-31.png (11kb) downloaded 0 time(s).Unfortunately there is nothing to choose from. What options are supposed to be available here? How do I get the select box populated with options again? Peter.
Just received the solution:
1. Go to Add Input -> Camera and click the pencil icon on the right hand side of the first dropdown. 2. Tick all the vMix Audio options in the list to re-enabled them. 3. Select vMix Audio in settings under the Audio tab. Thanks, Peter.
