petervk
#1 Posted : Thursday, February 21, 2019 5:26:17 AM(UTC)
petervk
Sorry if this is a stupid question but...
According to the documentation the Recording Setup page should support the ability to select the audio mix to record:
However this is what my Recording Setup page looks like:
So where is the Audio mix selection ?
Thanks,
Peter.
spencerm24
#2 Posted : Friday, February 22, 2019 1:50:24 AM(UTC)
spencerm24
Thanks,
Peter.
This is totally a guess, but is it possible you don't have A and B busses enabled?
#3 Posted : Friday, February 22, 2019 2:43:11 AM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
The option to select an audio bus will not appear if recording audio source in Settings -> Audio has been manually changed.
Change this back to vMix Audio and it should appear as expected.
petervk
#4 Posted : Thursday, March 7, 2019 5:25:56 AM(UTC)
petervk
Unfortunately there is nothing to choose from.
What options are supposed to be available here?
How do I get the select box populated with options again?
Peter.
petervk
#5 Posted : Monday, March 11, 2019 1:07:49 AM(UTC)
petervk
Just received the solution:
1. Go to Add Input -> Camera and click the pencil icon on the right hand side of the first dropdown.
2. Tick all the vMix Audio options in the list to re-enabled them.
3. Select vMix Audio in settings under the Audio tab.
Thanks,
Peter.
Similar Topics
Recording setup settings (General Discussion)
by Famous Pictures 12/11/2011 9:00:28 PM(UTC)
