JohnnyFlash
#1 Posted : Thursday, February 21, 2019 11:47:42 AM(UTC)
JohnnyFlash
Hey Everyone,
I know that there aren't a lot of us doing 4K production, but I have run into a weird problem.
I was running a GTX 1080 w/ 8GB of RAM and was regularly hitting 100% memory usage with all my Cameras and NDI sources.
So, I thought clearly I needed a card with more RAM. Enter the Titan RTX w/ 24GB of RAM. Sadly, I'm hitting 100% with the same number of sources.
Is this a problem with vMix not using all my GPU Memory? Or it is something else?
-Jerry
thanks 1 user thanked JohnnyFlash for this useful post.
prass on 3/5/2019(UTC)
#2 Posted : Thursday, February 21, 2019 12:23:25 PM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
JohnnyFlash
#3 Posted : Thursday, February 21, 2019 6:36:37 PM(UTC)
JohnnyFlash
That's a useful answer.
So how big is this buffer?
It seems that a 4K input takes about 12% of this buffer? Am I in the ballpark?
I know that my stream is out of the ordinary.
We have 9 Cameras, 4 of which are 4K.
We're also using Titler Pro for our overlays which add another 3 4K NDI sources. (Looks like I may need to switch to GT Designer)
Also we have a number of inputs that have full screen overlay frames.
Overall, our stream looks great, and I'm happy I'm using vMix.
I'm just trying to come up with solutions that I can implement with greater knowledge of the internals.
ggudnason
#4 Posted : Tuesday, March 5, 2019 4:44:20 AM(UTC)
ggudnason
Was thanked: 8 time(s) in 7 post(s)
Try enabling high input performance mode in vmix
Details here https://www.vmix.com/kno...2/optimising-performance
prass
#5 Posted : Tuesday, March 5, 2019 7:40:23 AM(UTC)
prass
Was thanked: 3 time(s) in 1 post(s)
I am using Vmix from 6 years. I have read all patch notes sines then. All knowlegebase, and i can't accept 3 different GPU-s, 2 different configuration and same performance. Next step is RTX 2080 TI and Radeon 7. 2 weeks i am reading game forums, Nvidia forums and DirectX forums to understand what is going on.
prass
#6 Posted : Wednesday, March 6, 2019 4:15:08 AM(UTC)
prass
Nevermind, with new patch, default settings and new preset (this take me 5 hours), now i can use 4 GB of video memory! Thanks Tim and Martin
Rodrigo Rey
#7 Posted : Tuesday, July 9, 2019 10:31:49 PM(UTC)
Rodrigo Rey
Brazil
Hi
Send to us your backstage (pictures), cameras, audio positions
hfabeby
#8 Posted : Monday, December 30, 2019 6:31:59 AM(UTC)
hfabeby
China
witch patch? How do you get it? Can you share it
daniel514
#9 Posted : Thursday, August 13, 2020 10:08:52 PM(UTC)
daniel514
Canada
Was thanked: 16 time(s) in 16 post(s)
Please share with us which patch you are talking talking about!
alba4347
#10 Posted : Monday, April 26, 2021 4:17:05 AM(UTC)
alba4347
Lithuania
Faced the same issue and was not able to find any way to change the GPU memory cache size.
BUT!
Just today found a workaround that helped remove this limitaton - Resizable bar:
https://www.vmix.com/kno...th-resizable-bar-support
Can confirm that it works like a charm on ASUS TUF X299 MARK2 + i9-7900X + GTX3060
Just don't forget to disable Compatibility Support Module (CSM) in MB bios, as recommended here:
https://nvidia.custhelp....bar-firmware-update-tool
