sontoloyo
#1 Posted : Monday, September 30, 2013 5:45:46 AM(UTC)
sontoloyo
Malaysia
Hi Admin,
Is there research to MAGEWELL XI006AE-PRO 6-channel capture card suport in vMix?
http://www.magewell.com/hardware/xi006ae-pro
Thank you
#2 Posted : Monday, September 30, 2013 5:50:38 AM(UTC)
Was thanked: 4657 time(s) in 1606 post(s)
The XI006AUSB is on our supported hardware page.
I imagine the PRO version is very similar and will work fine.
sontoloyo on 10/26/2013(UTC)
sontoloyo
#3 Posted : Monday, September 30, 2013 5:57:21 AM(UTC)
sontoloyo
Malaysia
Thank you for the quick response of his.
Some argue that the use pci-e is more stable than USB 3.0 connection.
Egriswold
#4 Posted : Monday, September 30, 2013 5:24:22 PM(UTC)
Egriswold
Was thanked: 33 time(s) in 32 post(s)
Viewcast 460e with the optional breakout panel can be configured to capture up to 12 inputes
thanks 1 user thanked Egriswold for this useful post.
sontoloyo on 10/1/2013(UTC)
Damn2Good4U
#5 Posted : Monday, September 30, 2013 7:32:49 PM(UTC)
Damn2Good4U
sontoloyo wrote:
Hi Admin,
Thank you
The above card works well with vMix... I have one....
Go for it...
thanks 1 user thanked Damn2Good4U for this useful post.
Ramón
#6 Posted : Wednesday, October 2, 2013 5:56:51 PM(UTC)
Ramón
It works perfectly, you may need to adjust the audio delay, if you lag, try 300 milliseconds
thanks 1 user thanked Ramón for this useful post.
Ramón
#7 Posted : Monday, October 28, 2013 3:41:52 PM(UTC)
Ramón
I installed the PRO version of this card and it works perfectly.
sontoloyo on 10/28/2013(UTC)
kayllastudio
#8 Posted : Thursday, November 14, 2013 1:44:33 PM(UTC)
kayllastudio
Was thanked: 11 time(s) in 6 post(s)
what these capture cards can work simultaneously with 6 ch perfectly in vMix?
