Joined: 7/6/2013(UTC) Posts: 45   Location: Slangor Thanks: 25 times Was thanked: 4 time(s) in 4 post(s)
Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
The XI006AUSB is on our supported hardware page. I imagine the PRO version is very similar and will work fine.
Thank you for the quick response of his.
Some argue that the use pci-e is more stable than USB 3.0 connection.
Joined: 6/29/2011(UTC) Posts: 314   Location: Florida Thanks: 6 times Was thanked: 34 time(s) in 33 post(s)
Viewcast 460e with the optional breakout panel can be configured to capture up to 12 inputes
 1 user thanked Egriswold for this useful post.
The above card works well with vMix... I have one.... Go for it...
 1 user thanked Damn2Good4U for this useful post.
Thanks: 1 times Was thanked: 6 time(s) in 6 post(s)
It works perfectly, you may need to adjust the audio delay, if you lag, try 300 milliseconds
 1 user thanked Ramón for this useful post.
I installed the PRO version of this card and it works perfectly.
Joined: 6/11/2012(UTC) Posts: 39  Location: jakarta Thanks: 34 times Was thanked: 12 time(s) in 7 post(s)
what these capture cards can work simultaneously with 6 ch perfectly in vMix?
