guztavo
#1 Posted : Saturday, February 16, 2019 3:06:50 PM(UTC)
guztavo
Hi! I want to know if somebody here has done a homemade battery pack or something similar to use with the spark.
Im using 10 AA batteries 1.2v getting 12v and working well. But want to know your experiences.
Thanks!!
Regards!
Barney Box Lane
#2 Posted : Sunday, February 17, 2019 3:55:09 AM(UTC)
Barney Box Lane
get a 12v power pack from Amazon so you know that's not the problem when there's a problem. They can be fairly bulky so you can't really have it all mounted to the camera you'll need a little bag for it, and you can also put the spark in it. Also in the bag put some shiney tinfoil at the bottom so you can easily see the lights are on, this helps if you put the spark in the bag because the switch is on the other side to the connection lights.
thanks 1 user thanked Barney Box Lane for this useful post.
guztavo on 2/18/2019(UTC)
guztavo
#3 Posted : Monday, February 18, 2019 9:43:10 PM(UTC)
guztavo
Thanks!!
mavik
#4 Posted : Wednesday, February 20, 2019 8:48:31 AM(UTC)
mavik
Was thanked: 197 time(s) in 177 post(s)
You can use a P-Tap battery with adapter to spark as well. Depends on what you use. Ronin has P-Tap. Some Pro cams as well.
guztavo on 2/20/2019(UTC)
Ario
#5 Posted : Wednesday, February 27, 2019 7:48:23 AM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
I know it's not a battery, but FYI the Spark can be powered over ethernet (PoE) with a PoE adapter/splitter
like https://www.bol.com/nl/p...02-3af/9200000055254940/
this one.
You will need a switch with PoE (15W). The Spark is not PoE by nature, hence the need for a splitter.
