thecloudmediagroup
#1 Posted : Thursday, September 26, 2013 2:23:41 PM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
How do you get the best performance when doing HD video in vMix? I am streaming at 480ish but am bringing in multiple HD signals. Does vMix perform better if the system resolution is your final streaming resolution or if you resize the video in FME within the streaming tab? I am having issues with dropped frames in my recording when having the full screen going to another monitor. I also sometimes have a sizable amount of dropped source in the info tab.
Quad Core i7
Black Magic Intensity Pro
8GB of ram
Have a ATI Radeon 6870:
USB to VGA output to Powerpoint Screen
DVI output to Primary Monitor
DisplayPort to Matrox DualHead2Go to Secondary Monitor (Other Applications) and Third Monitor for vMix Full Screen Output
Which gives the best performance?
Inputs: 1080i and 720p
vMix System Resolution: 854x480
FME Streaming Resolution: 854x480
Recording Resolution: 1280x720
or
vMix System Resolution: 1920x1080
or
vMix System Resolution: 1280x720
dundurs
#2 Posted : Friday, September 27, 2013 1:08:36 PM(UTC)
dundurs
Was thanked: 46 time(s) in 23 post(s)
FMLE resize uses more CPU than vMix resize, so you want to pass 1:1 video to FMLE.
My formula for vMix:
Output Size = Recording Size
vMix video device = FMLE resolution
This should work fine with progressive resolutions, but for interlaced you might lose interlace information along the way.
Dundurs
thanks 1 user thanked dundurs for this useful post.
thecloudmediagroup on 9/27/2013(UTC)
thecloudmediagroup
#3 Posted : Friday, September 27, 2013 1:23:34 PM(UTC)
thecloudmediagroup
Awesome, good to know!
Now I just need to figure out why I am dropping source frames in that analysis window.
