Crackling Audio Using Virtual Audio Cables and Zoom
Joined: 2/1/2019(UTC) Views messages in topic : 1  Was thanked: 3 time(s) in 1 post(s)
Originally Posted by: mgrayeb  ask wrote:Audio crackling often indicates overuse of the CPU. Use Perfmon as you test to see what is going on.
Thanks for the suggestion. I ran the performance monitor and my CPU was hovering between 10% and 20% so no issue there. Sorry for joining the discussion so late, I didn't see it before. With VAC 4.50 and 4.51 that support RT Audio (WaveRT) and default to this mode, popping/crackling might occur due to KS buffer size limitations in Windows. There was a workaround (setting Ms Per Int to 1..3 ms, or change port type from WaveRT to WavePci or WaveCyclic). In 4.60, this problem is fixed.
 3 users thanked emuzychenko for this useful post.
